Although they are a couple of people that have done the E60 CIC retrofit overseas it hasn't been documented with pics. Hopefully this log will help those that are hesitant or not sure of whats need it for the retrofit.
I received most of the parts that i needed for the retrofit. Still waiting for a couple of parts that should be here on Friday. Looking at doing the installation,coding and programming sometime over the weekend with Patryk. Wanna thank R9ndy and Technic for all the help in getting the right part numbers. http://i181.photobucket.com/albums/x...IMG_0270-2.jpg http://i181.photobucket.com/albums/x...IMG_0279-1.jpg http://i181.photobucket.com/albums/x...IMG_0278-1.jpg http://i181.photobucket.com/albums/x...IMG_0277-1.jpg http://i181.photobucket.com/albums/x...IMG_0276-1.jpg http://i181.photobucket.com/albums/x...IMG_0275-1.jpg http://i181.photobucket.com/albums/x...IMG_0274-1.jpg http://i181.photobucket.com/albums/x...9/IMG_0272.jpg http://i181.photobucket.com/albums/x...IMG_0271-1.jpg http://i181.photobucket.com/albums/x...IMG_0269-1.jpg |
Very nice...Hope to see more pictures soon :thumbsup:
And he is off!!!
Good luck Nelson with this interesting project. I will be following very closely and learning from you to repeat soon. https://5series.net/forums/public/st...ault/twoup.gif |
Nice GL would this be for the Pre-LCI to the LCI center console? Let us know how it goes and if it would work for a non navi. GL :twoup:
Good luck with this. I shall be monitoring with interest. Any chance you could post part numbers as well?
Originally Posted by NC916
(Post 1184538)
Originally Posted by kakalika
(Post 1184564)
61119185171 CIC HD Screen cable 61319167196 USB Port 61129196805 USB Port cable 51456976361 CIC Center trim 61136954526 CID CAN/power connector Everything else is based on the year of your car and your wood trim. For those who own LCI cars you have less parts to buy than those with Pre-LCI cars. If you have a LCI car the only parts you need to replace is the center trim and support bracket for the new idrive controller. If you have a pre-lci be prepared to spend about $400-$600 for the lci conversion. |
Dam IC how about the settings still the same or your going to do the LCI screens?
(Post 1184657)
the menu screen is like different from the LCI to PRE-LCI, like the climate entertainment.
