CCC sound system vs CIC sound sistem
Hi guys,
Quick question (I tried searching but did not find any info regarding this matter).
I upgraded my CCC professional to CIC. Installation was easy, but I have a minor issue. The sound system now sucks.... before I had deep bass and the sound was crisp and deep at high volumes, now it sucks big time, there is almost no bass, the volume is not as "loud" and deep at is was before. The woofers are connected, they work, but the sound is terrible.
The CIC unit is codded correctly with my sound option (SA676 HIFI LOUDSPEAKER SYSTEM).
Anyone else have this problem?
Please, any help or information is GREATLY appreciated.
This is a known issue. I belive there is a post on what the fix is in this thread:
https://5series.net/forums/e60-parts...-99495/page94/
My Ride: M3
Model Year: 2017
The CCC SA676 outputs high level, high pass front and rear signals from the CCC, and balanced, low level, low pass signals to a separate OEM amp in the trunk to power the underseat woofers.
The CIC SA676 outputs balanced, low level, full range, flat signals to a separate 6-channel OEM amp in the trunk.
That is the cause of your audio problem.
One way of solving that is to replace your current OEM setup with a 6-channel aftermarket amp that accepts balanced signals. That will power all your current 6-channels (front, rear, underseat).
The other way involve tapping the rear outputs of the CIC to the inputs of the OEM amp at the rear of that CIC in your car. The problem of that is that you will be powering the front and rear speakers with a low level signal which most probably you will not like the way your system will sound.
Hi guys,
This affects people who have the Hi-Fi option only (US std). Logic 7/Individual and EU basic are not affected.
Technic has explained why.
3 options.
1. Buy and replace the OEM amp with a CIC Hi-Fi amp. This is best OEM solution. Problem is that these amps are hard to come by in the 2nd market.
2. Install a MS-8 or similar.
3. Use a four channel amp in the rear to drive the rear speakers and the underseat woofers. Use your current Hi-Fi amp to run the fronts, This avoid too much wiring. Allows you to reuse your old amp.
Technic can fix you up with wiring sets for 1 and 2 atleast.
I myself am considering if I should in the CIC Hi-Fi amp. I am lucky to have found one but that will mean going back to the OEM woofers and remove the Earthquakes I have now.
3 options.
Thank you all for your input.
I can purchase a Prologic 7 amp (SA677) and speakers. Will this swap resolve this issue? As to my knowledge the DSP amp is hooked up with the cic through fiber optics, and all the wiring go from the amp to the speakers. Is this correct ?
Thanks again for all your help.
My Ride: M3
Model Year: 2017
My Ride: 535 E61 2010
3 options.
3 options.
Can you also explain what wiring harness changes are needed to make this work correctly?
My Ride: BMW
After I did the CIC mod, I did this with Technic's cables.
https://5series.net/forums/e60-parts...nstall-124141/
My Ride: 530ix
Model Year: 2020
3 options.
3 options.
I am just not savvy enough to understand why this matters since they both pass stuff to an OEM amp in the trunk, which should be doing more work than it is.
any help appreciated.
mishka69
06-19-2015 04:30 AM
incoherent
04-15-2015 04:48 PM
