CCC to CIC Retrofit parts
Hello Everyone,
I have E60 535xi(with the Sport Package) with CCC, I found an wrecked E60 with CIC. My question is do I simply remove the screen, the CIC unit containing the hard drive, and the climate control panel, and the Comm Box? Then just recode them to my car. |
Hi Jake, you need:
- CIC Unit - Screen - Cable between cic unit and screen - climate control with front panel - combox - usb cable |
Originally Posted by Vlad525
(Post 1598867)
Hi Jake, you need:
From what I know is not the same, you have the usb from the mulf 2 high....am I right? The CIC used it's own USB port (2 usb ports). Hope this helps!
Hi sorry to hijack the thread. I have all the items from above, minus USB port and cable. I also have the CAN filter, lci climate controls and panel. The cic unit is preloaded with maps and ‘free coded’. Is this all I need to make it work? also, currently I have a ccc unit with BT option, how do I connect the BT module to the cic unit? and as a last issue: is it possible to get RTTI information on the cic navigation at all? thanks a lot |
Nice to see this thread is helping people. If anyone needs help / remote coding please contact me via private message.
Originally Posted by TeflonDon
(Post 1612058)
also just got a F10 535xi with a pretty nice system. Since the car is going to be parted out, I will be pulling out that system as well. |
