Can I replace door bulb from 5W by 10W
My Ride: E61 525dA, High Executive, Xenon (AHL), leather+memory, CCC Prof, pano-roof
Engine: M57 (256D2)
Hi all,
As far as I know the bulbs in the doors (under) are 5W type. I would like to have a more intens light when opening the door. Can I replace the stock 5W by 10W of does this trigger an error?
I like the yellowish color, that's why I do not want to switch over to LED.
I think that those are T10 bulbs. Try the 10w and see. You will pull more amps, but shouldn't blow a fuse.
Engine: M57 (256D2)
Thnx for your reply. I will try a 10W bulb first, but I wonder whether this will not introduce too much termal issues (overheating, melting of plastic).
I have also seen there are LEDs available which gives "warm white" color (T10 LED). Maybe I will try this also. There are a lot of different SMD-LED with various output brightness.
I will update this post as soon I've tried some alternatives.
The LEDs will not cause heating problems, but might trigger warning indicators.COLOR]
Last edited by FormerE30Owner; 03-06-2018 at 12:28 AM. Reason: sentence construction!
Engine: M57 (256D2)
I will try today removing one bulb to see if it throws an error. Maybe there is no CAN-bus check on these lights...
bip78
13
11-07-2011 11:47 PM
POGI
DIY: Do It Yourself
02-12-2007 01:02 PM
