Board level ECU repair
Old 06-06-2019, 03:27 AM
sjeppell's Avatar
My Ride: 2006 530xi loaded
Default Board level ECU repair
Does anyone have a recommendation for an outfit that does board level ECU repair. I'm fairly certain I fried a bit of my CAS when a piece of aluminum foil used to cover an intake runner fell into the engine bay and briefly shorted the starter leads. The starter motor still spins if I disconnect the line from the CAS and short the leads, but when I check the voltage at the disconnected lead when I turn the key, it never comes up from ground (i.e. the CAS is not signalling the solenoid to activate). I pulled the CAS unit and looked at the board and there's no obvious damage but as far as I can tell, it's the most likely culprit.
Thanks, Steve
Takechan
03-31-2014 11:20 AM
Darwin@SonicMS
Group Buys
08-28-2008 03:17 PM
555
Site Comments & Suggestions
14
04-19-2004 10:42 AM
rodybmw
10-18-2003 11:43 PM
theKupe
06-03-2003 09:28 AM
Quick Reply: Board level ECU repair
