BMS Power Box Performance Tuner for N52
Old 08-05-2010, 10:53 AM
mannynj's Avatar
Came across this, but didnt see anything come up on a quick search here. Is this essentially a Sprint Booster-like product?
Interested since it obviously seems to be focused on the N52, which i have. Hard to believe the performance gains advertised, but i'm sure with better breathing through some mods it could possibly have a considerable cumulative effect towards some gains.
http://www.modbargains.com/BMS-Power...-328i-528i.htm
"Finally, thanks to Burger Motorsports there is a tuner available for the N52 motor (128i, 328i etc. See below for a full list of applications). The BMS Power Box remaps the throttle mapping for better throttle response, and an increase in horsepower and torque. The Power Box features easy installation and removal, and gas pedal switching between 7 performance maps. The Power Box shows power gains from 8-10 horsepower and 8-10 Ft./Lbs. of torque at the rear wheels on a dyno. Upgrade your vehicle's power and drivability with the BMS Power Box.
The BMS Power Box is purely plug and play and installation only takes roughly 20 minutes, and only requires basic hand tools. It is completely reversible, and no cutting of any wires is needed. Installation is very discreet and allows most customers to leave the Power Box installed for routine service.
Benefits & Features
* 100% Plug and play
* Gains of 8-10 horsepower & 8-10 Ft./Lbs of torque at the rear wheels
* 7 available maps
* Easy switching of maps can be changed from the drivers seat
* Improved throttle response
* Compatible with both N51 & N52 motors
Applications (US Models)
* E90/E91/E92/E93 325i/325xi
* E90/E91/E92/E93 328i/328ix
* E82 128i
* E83 X3 3.0si
* E70 X5 3.0si
* E90 330i/330xi
* E85/E86 Z4 3.0i/3.0si
* E60/E61 528i/528xi
* E60/E61 525i/525xi
Map Guide
Map 0 - Disables BMS Power Box, all signals pass through
Map 1 - 30% throttle remapping, performance tuning on
Map 2 - 60% throttle remapping, performance tuning on
Map 3 - 100% throttle remapping, performance tuning on
Map 4 - 30% throttle remapping, performance tuning off
Map 5 - 60% throttle remapping, performance tuning off
Map 6 -100% throttle remapping, performance tuning off
Map 7 - throttle remapping disabled, performance tuning on
Applications (European Models)
* E90/E92/E93 330i/330Ci
* E82/E88 125i
* E60/E61 530i
* E83 3.0si
* E70 X5 3.0si
* E85/E86 Z4 3.0si
* E89 Z4 sDrive30i
* E63/E64 630i
* E65/E66 730i
* E60/E61 523i
* E90 323i
* E83 X3 2.5si
* E85 Z4 2.5si
* E89 Z4 sDrive23i
How to Switch Maps
Insert the keyfob and press the start button to turn the ignition on (lights on the dash but the engine is not running). Press and hold the gas pedal down to the floor for 4 seconds or more, then release. This puts the Power Box into listen mode. If you start the engine at this point you will be on map 0. For performance maps press the gas pedal to the floor and quicly release one time for each map you would like to select. For example, for map 3 press and release the gas 3 times, then start the engine. Your map setting will be saved until it is changed."
Anyone know anything about this?
Old 08-05-2010, 11:04 AM
Cal@Jlevi SW's Avatar
The BMS PBX unit by itself will be good for 10hp/10tq. Couple it with intake and exhaust and you should be good for 15-20hp gains total...
It's not too popular with the E60 crowd but if you do a quick search on E90post you will see loads of satisfied users. Let me know if I can get you a price on one of these units
Old 08-05-2010, 11:30 AM
mannynj's Avatar
Thanks Cal. Almost sounds too good to be true based on what i'm reading, but the customer dyno's are impressive considering the cost/practicality of this modification.
Feel free to PM me with a quote, its a mod that'll have to prioritize in the coming weeks.
Old 08-05-2010, 12:58 PM
Sure thing! PM sent
Old 08-05-2010, 02:43 PM
sachal007's Avatar
My Ride: BMW E-60 530I
why is it not very popular among e60 group?
Old 08-05-2010, 02:57 PM
Bezzletine's Avatar
It is. If the search function wouldn't have changed you would have come across a lot of results.
Old 08-05-2010, 04:19 PM
AC525's Avatar
Is it similar to juice box for 335 or 535i?
Old 08-05-2010, 07:40 PM
Banned
Diamond's Avatar
I have had it installed for 3 months now and LOVE the thing. It totally transforms your driving experience. The throttle response is so much more direct and immediate as well a nice kick in power that is definetly noticable. What sold me on it were the tons and tons of positve reviews and literally not ONE negative review. There are atleast 3 or 4 dynos around showing good gains and more importantly than peak gains, there are consistent gains across the entire powerband. Search on the e90post.com boards and you will see countless good reviews.
For the 300 bucks it is really worth it-you can turn it on and off and you really notice the difference after having it and then turning it off-your car feels like an absolute slug without it-go for it.
It is not really like the JB3 as that pretty much increase the turbo boost as well as ignition timing and a/f ratio but really its ramping up boost and that is why it makes big hp.
On the n52 naturally aspirated-the changes the tune makes is twofold-it advances spark timing more than the max advance of the stock computer. It also richens the a/f mixture-so across the entire band and even more at WOT you have a richer mixture. This is done in order to more safely advance the spark timing-so you dont run the risk of detonation from early spark advance-rich mixtures resist detonation. Plus it maximizes a complete burn when there is ample fuel for the air. Stock system goes rich when at WOT so that is how max power is typically created.
Also of note gas mileage for me actualy improved consistently over 3 months by 1.5 mpg-so its a win win situation
Old 08-06-2010, 04:12 AM
mannynj's Avatar
Very good, thanks for that feedback Diamond.
Cal, are there any dealers/installers you can refer on the Nj/NY metro area?
Old 08-06-2010, 04:44 AM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
Ice had it since early spring, you can notice the difference when you turn it off. Best $300 I spent on the car. I never switch maps, always use it on map 3.
Install isn't hard, follow the instructions and do it yourself.
Quick Reply: BMS Power Box Performance Tuner for N52
