ALMOST THERE... Need some advice though... WHEEL GUYS GET IN HERE!!!!!!..(PICS)
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
Soooo I've been debating whether to by these Varrstoen ES1's with 20x10 et15 up front 11 rear. So i finally pulled the trigger wheels have arrived time for the test fit Im a little unsure but I definitely think this can work. Rear fitment is no problem. I do have some question about the front after the test fit. I cannot mount tires yet because I have to get the wheels PC'd and dont want to spend the money to dismount/mount and yet again when wheels are done.
1. Is this enough clearance from the wheel to the shock body? ST/KW calls for minimum 5mm I think I can get away with this gap not sure tho. If not I will buy the 5mm spacer w/hub extender. That Problem should be solved.
2.Pic with black line and measuring tape shows where my suspensions previous position (black line) vs now where I had to raise it in order to clear the perch. Is this enough clearance between the bottom of the perch and the rim, if in fact I can get the tire not to rub the perch (hypothetical)
I have a pic of my wheel as it sits currently at the black line the difference from that and the adjustment to clear the perch is about a pinky no larger not a big deal to me. Showed the measurement so you all can get a prospective. Tires will be stretched so wheel wont come all the way to rim edge anyway. I am thinking I can make this happen with the 5mm spacer to add clearance to the shock body (unless you guys think that is enough space) and if I can get the TIRE to clear the perch. What are your thoughts?
All alone on this Island I guess can a brother get some advice?
That should be enough space however you will want to run a little bit stretched on the tires so it clears. Make sure you tighten the locking allen so the perch doesn't move.
I was hoping someone said that my plan was to already run a stretched tire. I was considering buying a 5mm spacer just in case. Will i need a hub extender with the spacer of that size or should I be ok. I would rather not use a spacer though because I dont want vibration issues. Its a tight fit but definitely seems doable. just didnt know if that was enough clearance for either scenario.
I think I've voiced my opinion on the fitment haha. I say get spacers.. I think you'll need them. What you should do is sell me two of the 20x10's and buy two 20x9's for the front. Mine fit so perfect. I have been thinking about a small spacer up front tho for moar flushhhh. Good luck, post some pics when your fitted!!
Hey bro's it's me again... I have one more question for you. I finally got the wheels fitted this thing looks sick and have 0 rubbing issues with the front with a 225/35 on a 10 w/5mm spacer. I am planning on going up on the spacer width to a 12mm because I have plenty of room because of the tire stretch. It has been spoken about that front or rear ends are not equal on Both sides. My car the driver side wheels sit out further than the passenger. Looks uneven when I look at it dead on in front of the car. My question is can I run different size spacers from passenger to driver to even things out. It would make sense to me but idk if this has been done. I've test fitted and drove the car with 15mm spacer in the front. Passenger side fits perfect no rubbing but driver rubs a little bit. That's why I want to drop to a 12 to help the driver side. Need some advice on this one. Pics are with 15MM Spacers front (not a typo) lol....
Damn that is hella stance. I'd be a little concern at the actual rim of the wheel hitting the fender if you hit a big enough dip or bump. Your tires should clear for the most part since they are stretched as f***. For the wheels being off I found that mine were off only 2mm based on the clearance I had between the perch and the inner wheel. I personally would run the same size spacers on both sides. Just my 2 cents.
to arrive. Wash it up and Ill post some pics. Appreciate you helping out on my questions, topic got alot of views but not much input.
Nice set up sir!!! More pics
let see some sideview ones
