08 535i build
#21
My Ride: 535i
Model Year: 08
Booster line
Starting to put the rest of the brake booster line
Moving along...
Complete...
Installed...and hidden
New solenoid set up....
The other vacuum hard line that goes into the fender.. this comes from the module that eventually plugs into the throttlebody
New oem end installed.
Installed...
A/c line protected and the coolant lines in oem bracket.
Bracket cut and sealed with gasket maker.
Ryan
Moving along...
Complete...
Installed...
Ryan
#22
My Ride: 535i
Model Year: 08
Time for some more updates......
A/C
No A/C line = a lot more room....
Last shot of cooling
Gone.....so much room.
29.5" of room.....hood closes just fine.
Initial relocation..... no good.
Mocking up a new bracket. This is from the NMP RELOCATION kit..... also mounting the washer fluid hose here.
Cut part of the oem bracket for washer fluid
Washer fluid cap
I used various clips and bolts from removed parts or parts laying around like this.
attached to bracket....
Installed
I have many more pictures to upload but have to get back to other things......stay posted.
A/C
Washer fluid cap
Installed
#23
My Ride: 535i
Model Year: 08
Bracket And final instal pics...
Finalized before paint...
Installed...
Foam pad for protection...
Hose set up.
Next up was praying the a/c line that was made for me fit.
It's going to be close....
Whew!:happy
Canister
Rear intake pipe on. Getting messurements for Y
Modified MMP intakes to fit Y pipe.
Front intake on....
Y pipe
Ryan
Installed...
Hose set up.
Whew!:happy
Canister
Front intake on....
Y pipe
Ryan
#25
My Ride: 535i
Model Year: 08
Took off the ******** brackets.
The rear intake clamped on...
New heat sheild with OEM solenoid bracket...
Modifying....make sure to keep two bolt holes. See my mistake.
Test
Mounted
Test
Mounted
#27
My Ride: 535i
Model Year: 08
I plan to repair my leaking dynamic drive sways. But have thoughts of completely removing this system. I feel like having solid sways will eliminate one more thing that can go wrong as it currently did.
I plan to remove them, clean them, reapply new sealant to the boots and re-install. Not sure if this will work, but it beats paying $1800 for a new sway bar. For that price tag it has to be less expensive to remove the system.
Pump
Ryan
Pump
Ryan
#29
My Ride: 535i
Model Year: 08
I'm going to add various pictures that I took that may be helpful that never got added. Sorry for these being out of order.
Removing and rerouting
Remove this end..
install in heatsink....
Cooling hoses relocated...
Remove this end..
#30
My Ride: 535i
Model Year: 08
Got my Bimmer Geeks cable and BMW Standard tools installed. Plus scanned my car with MHD and came up with this.
This fault was fixed with a low-pressure fuel sensor located under the intake manifold.
