Will these Wheels fit?
Hi,
I have a set of G power wheels
front axle 9,0 x 20 ET40
rear axle 10,0 x 20 ET40
I have the wheel spacers from 18 mm and 22 mm.
The wheels fitted my E61 x drive but now i want to put them on my M5.
Thanks for your help
problem solved,
all wheels of G Power have ET40 and thay let it fit to every BMW model with mounting kits,
for m5 i will need the 31mm mounting kit for the front.
and the 18mm kit for the back
So we will have ET9 in the front and ET22 at the rear.
thanks for all the replies guys
PS : so the story of spacers is bad is blablabla because they use it standard,
and also G power has the fastest M5 ever known......
spacers are fine to use, although 31mm on the front is on the huge side. The only thing you have to worry about is that they are perfectly machined just a little off and you'll get some serious wobble in the steering wheel.
asinner
05-06-2015 06:03 PM
bestofthebest
03-30-2015 08:12 PM
