Wheel Fitment Help
Found a nice set of wheels but they are a square setup and look amazing. Im thinking of getting them but only if its possible to reuse my current tires of my current 20" rims.
Here's the spec of the new wheels: Size= 20x10.0 Offset= 20 Center bore= 74.1
would it be possible to re-use my current tires? 255/35/20F & 285/30/20R
would i have to stretch the tires?
Thanks
Thanks
Thanks for the info but wouldn't it look kinda dumb with the front being streched and the rear not. Maybe i should go with a different tire size in the rear instead of 285 maybe a 265 with a stetch. What do you think?
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
Question: Would a 305/25 look okay on a 10" wheel?
not sure if 305 would even fit right but Im sure it'll be too square of a set up
Yes you will most likely will switch to 245's instead
