V10 ENgine vibration
I have been getting a vibration like a shuddering of the car when revving in neutral or in gear between 1100rpm - 1300rpm and then 2100rpm - 2250rpm.
Anybody experienced this?
I have been in another car and there was no vibrations at all.
Checked pulleys, had a new belt go on A/C tensioner and vibration is still there.
I had the exact same problem on my 545 it turned out to be that the dealer overfilled the engine with oil. Check that maybe just pull a little oil out and see. On the M5 it should warn you but it might just be a tad over. The 545 never threw out a warning at me. Run a search on my name and engine vibration. I might have posted more details.
Nothing to do with engine oil as my engine oil drops nothing is changing....
Anyone with some info?
I have heard that it maybe the flywheel bolts being loose, or the vanos units...
hmilycar
06-20-2015 01:46 PM
