Stock vs Dinan 3.91 Differential - Results
Old 01-17-2007, 08:34 AM
550isport's Avatar
My Ride: 07' 550i sport; Sapphire Black/Auburn; sport package; steptronic; navigation with R.T.T.I.; heads up; cold weather package; Logic-7; BMW MOST ipod kit; Motorola V3 snap-in adapter; rear heated seats and rear shades; anthracite headliner; sirrius sat. radio; M-aero kit; OEM style 166 Wheels with 245/35-19 front and 285/30-19 rear Michelin PS2s.
Originally Posted by JetBlack' post='377408' date='Jan 12 2007, 07:00 PM
I know for a fact that they will only offer the 3.45's for the 545/550 and 3.91's for the M's. The reason they will stick with this ratio is because it will still allow you to hit 60 mph without a 2-3 gear change.
(my brother works there, in sales)
Jet Black,
Do you know why it is that the Dinan diff can only be used with a manual trans? My 740i sport had an OEM higher stall speed torque converter and a higher rear ratio than a standard 7 and it was an automatic? Just curious since you have a connection at Dinan...
Thanks,
DRP
Old 01-20-2007, 12:32 AM
alpineweiss's Avatar
My Ride: 09 E90 M3
Did you notice a change in the way each gear engages after a downshift? For example when off throttle, the blips for the downshift seem about 200 rpm short of perfect for my regular SMG (and I heard so too for M5)...I'm wondering if the lower diff ratio affects this.
Old 02-02-2007, 06:14 AM
wolverine's Avatar
No changes whatsoever in the shifting. Except when you nail it, the shift points come up a lot quicker .
In normal driving, the diff is exactly the same as stock. Even the rpm increase is difficult to notice. For example, cruising at 70 mph in 7th gear, you're at 2900 rpm instead of 2700 - really impossible to tell the difference by ear. The only other significant difference is it won't automatically upshift at full throttle in D mode. That will be corrected with Dinan's upcoming chip, which should raise the rev limit, remove the speed limit, and supply some extra HP!
Old 02-02-2007, 01:31 PM
xexyus's Avatar
My Ride: 05 530 Titanium Silver/Sexy black
I heard that with that differential plus the rest of the mods there was no significant increase in HP. I was reading a real good writeup on m5board of a guy with an M6 who had that differential and he had no significant gains. In the end I believe he said that his gearing was the problem but im not sure..
Old 02-03-2007, 07:00 AM
wolverine's Avatar
The differential doesn't add any engine hp, but the performance increase is like adding an extra 40 HP. What the diff does is add 8% more torque to the rear wheels, in any gear, at any speed, so you're accellerating harder at all speeds. It's definitely the best bang for the buck modification you can do to this car (other than removing the charcoal filters). The guy you're talking about is having issues related to multiple modifications, and not getting the HP increase he expected. In no way is the differential hurting his hp measurements.
The top 2 M6 times on dragtimes.com are using the Dinan differential, 12.1 @ 120mph, and 12.3 @ 121 mph. Pretty good ET's for 2 second 60' times.
http://www.dragtimes.com/results.php?carmo...earch+DragTimes
Old 02-03-2007, 07:59 AM
Alex.br's Avatar
My Ride: 2007 E60 M5
Wolverine,
Will loss Vmax a delimited M5 with this diff comparing to OEM delimited one?
Thanks,
Alex
Old 02-03-2007, 04:08 PM
wolverine's Avatar
Originally Posted by Alex.br' post='387140' date='Feb 3 2007, 11:59 AM
Wolverine,
Thanks,
Alex
Sorry Alex - I don't understand your question.
Mike
Old 02-03-2007, 04:16 PM
Alex.br's Avatar
Mike
I was asking about the top speed in delimited cars (with Dinan and oem).
Old 02-03-2007, 06:42 PM
wolverine's Avatar
OK, if you figure the stock M5 is geared for maximum top speed, that puts it at 204 mph at 7960 rpm, very close to the HP peak of 7750 rpm. With the Dinan, you would need to run almost 8600 rpm to hit 204. More likely you would be able to hit redline of 8250, which would give you a top speed of 196 mph. But, the Dinan 3.91 will get to 196 mph a lot quicker than the stock car!
Old 02-04-2007, 02:51 AM
Alex.br's Avatar
Thnaks Mike. Now it is clear to me.
PelicanParts.com
07-23-2015 01:01 PM
PelicanParts.com
07-23-2015 12:50 PM
PelicanParts.com
07-23-2015 12:41 PM
PelicanParts.com
07-23-2015 12:29 PM
Quick Reply: Stock vs Dinan 3.91 Differential - Results
