Shaking steering wheel after Eibach springs fitted ??
Hi,
I have fitted Eibach springs, after 100km i did the geometry of the car again, but now i have some shaking in my steering wheel.
I have feel the car shake a little bit.
What could it be and who had it also after the fitting?
New tyres, new brakes so this cannot be the issue.
Please help?
thanks
Filip
Please help?
thanks
Filip
Yes i did the wheel allingment after 100km like the garage told me.
Maybe i have to perform it by a bmw dealer, they know maybe better then a tyre dealer.
thanks for the fast reply.
My Ride: 05 545/6
Originally Posted by Filip535D' post='901197' date='Jun 4 2009, 07:09 PM
Hi,
Also, you might want to check to see if any of the wheel weights have fallen off (or were knocked off when alignment or spring install was done). This would cause a severe vibration too especially at speed.
My Ride: 2004 645cic, 20" asanti wheel with KW Coilover Variant 3
if your steeling wheel is shaking from breaking while reducing from high speed! Then it could be a bad rotor, i have the same problems before from some aftermarket rotor on my old Lexus! most BMW don't reservice their rotor they just replace it. but if you have aftermarket one you might just want to try to reservice it and see does it work?
Hi,
1. eibach springs and brake fitted ( stoptech ) , no problems until after 200km
Car vibrates completely
2. Allignement of the wheels done
3. tyres changed
Still vibration of the car mostley at the front ( and also in the steering wheel.)
thanks for the help
3. tyres changed
thanks for the help
Originally Posted by Filip535D' post='902064' date='Jun 5 2009, 03:25 PM
Hi,
3. tyres changed
thanks for the help
3. tyres changed
thanks for the help
have your upper control arm bushings checked and replaced them. chances are they're worn or near it's useful life. these bushing are always under a lot of stress especially at takeoff and hard braking, let alone the engine weight. this should solve you problem. good luck
Originally Posted by pjinca' post='902095' date='Jun 6 2009, 06:54 AM
Again, check the wheel wieghts - they usually remove these when they change the tires because no 2 tires are balanced equally. If it's not the wieghts you will have to have someone take a look at the tie rod ends, they shouldn't have been loosened, but I have seen bigger screwups at shops.
