Question on M5 brakes
Originally Posted by AlexFW' post='594331' date='Jun 3 2008, 04:31 PM
...nobody would get rear brakes to brake better .
You must understand that rear brakes are not there just for the hand brake, but most importantly they are supporting the front brakes against overheating on heavy, high speed braking situations, especially when the car is loaded
M5 rear: 370x24mm semi-floating, compound, drilled, with directional air ducts, light-weight rotors
550i/545i/535d rear: 345x24mm compound rotors
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
Originally Posted by nicke60gre' post='594352' date='Jun 3 2008, 04:30 PM
..not really, the M5 which is the most powerful BMW ever made (so far) has them ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
M5 brakes are better than 545/550 brakes but if you need to play hard they are weak: only you with 170 HP and Andy545 who use them on highway can be so happy .
My conclusion is a good upgrade, with the BMW logo (and it is useful because we can't swap brakes here and with BMW written on the caliper in an accident the police wouldn't notice them) and with pads/rotors are available in each dealer in the world .
M5 rear brakes are 1 piston and the drilled feature is useful on track to allow the dust from the pads to come out through holes .
which they also have very good rear brakes compared to the plain steel rotors (530i, 525i, 520i, *.*d)
Try to play a bit : brake hard then accelerate and let us know .
My Ride: 545i Sport
Engine: N62
They (M5/535/545/550)all share the same rear wheel brake pads. Meaning same pad/rotor surface contact, regardless how big(or heavy) the rotor diameter. They look identical anyway.
11 REPAIR KIT, BRAKE PADS ASBESTOS-FREE TEXTAR T4166 1 34216768471 $112.16
Source:
E60 545i REAR WHEEL BRAKE-BRAKE PAD
E60 550i REAR WHEEL BRAKE-BRAKE PAD
E60 M5 REAR WHEEL BRAKE-BRAKE PAD
You also need 19 inch wheels to accomodate bigger M5 calipers. I switched from 124s to M166s.
-Joe
Source:
-Joe
My Ride: 14 550i
i beg to differ.
cross drilled rotors are to help dissipate heat better. However, the structural integrity is compromised causing them to fail quicker. The rotor I'd go for is slotted which dissipates heat better than normal rotors yet has better durability when compared to cross drilled.
though... cross drilled looks sexier![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
michael
michael
The difference, I bet, can't be so much, between one piston and one piston with drilled rotors (and I repeat, holes are made to allow the dust ... on track - The Alpina B5 doesn't have drilled rotors and neither the 760i)
My Ride: 545i Sport
Engine: N62
Originally Posted by khooger' post='594014' date='Jun 2 2008, 07:10 PM
So can somebody confirm that the M5 E60 front and rear brake rotors, calipers, discs and the whole deal....fits my 545 with no issues? I have on the 167's. ![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
My Ride: 14 550i
To add
When you brake it produces gasses, the cross drilling also helps the gasses escape thereby increasing contact pressure.
Michael
Michael
Originally Posted by myfootsmells' post='594565' date='Jun 3 2008, 12:08 PM
i beg to differ.
michael
michael
Source:
-Joe
Source:
-Joe
I have the m5 rotors and calipers front and back. The front has no issues with installing. The rear rotors doesn't fit the back completely without removing the metal bracket. YOu'll find out when you install it. As far as with rims, i have 20" rims so the clearance is fine, not sure about 18" rims fitting on the m5 rotors.
![Question on M5 brakes-protplat.jpg](https://5series.net/forums/attachments/e60-m5-discussion-3/51858d1482364086t-question-m5-brakes-protplat.jpg)
18" wheels (8JX18 ET:14) are available by BMW for the M5/M6
http://www.realoem.com/bmw/showparts.do?mo...hg=36&fg=15
