Perforated Seats Lumbar support?
I have tested the 20-way multifunction seats with active width adjustment on the M5. It's awesome how the side lumbar supports you and moves up when you are making twists and turns. But on the upgraded perforated merino leather seats, can you also have the active width adjustment? Or do you have to sacrifice plush seating for lumbar support?
thanks guys! I just thougth that the perforated looked VERY plush and did not wrap around the body like the 20-way multifunctionals do, so was not sure if they had active width adjustments.
Do the standard 14-way seats (no upgrade) offer active width adjustments?
thanks everyone. But does the normal 14-way seats have the active lumbar support? If you look at this interior pic, if I remember correctly, there is usually a button next to the heated seats button that has lumbar support. I do not see it on this car.
http://www.cars.com/go/search/detail.jsp;j...mp;aff=national
How do you tell if its 14-way or 20-way seats? Do they look the same?
I remember that there is a button right next to the heated seats button,......I think that was for lumbar adjustment, but not sure. It is missing on this silverstone.
The comfort seats that are ventilated (only seats you can get with ventilation) also have the active side bolsters, but they don't have the "sportier" look of the standard seats. They are basically the same seats as the comfort seats in the 5 or 7-series, but with the active bolsters for the "M experience."
You'd be hard pressed to not find an M5 or M6 without the active side bolsters, regardless of which seat is installed.
bestofthebest
01-05-2016 07:47 PM
ucsbwsr
09-19-2015 10:58 AM
