New E60 M5 Owner
Hi everybody!
I just recently purchased a 2006 E60 M5 with SMG. The car was really well-maintained, and all the main maintenance was taken care of. (rod bearing, vano hp lines, engine mount, throttle actuator rebuild, belts... etc.) There are a couple things I look to do to the car... exhaust upgarde maybe.. bmc air filter change, headlight light bulbs upgrade? headunit upgrade and need aux conversion For the exhaust, i'm considering a muffler delete or eisenmann? not sure if muffler delete will be too loud Can someone help me understand which light bulbs wll be needed and if I need to remove the whole headlight units to upgrade the bulbs and such Also for the headunit upgrade what parts do I need for 1. the headunit itself, aux kit?, and aux aux activator? Also my windshield wiper fluid stopped working, i'm not sure if its the pump or a fuse pop. Does anyone which fuse it is? is it in the glovebox or is there another one in the trunk? Are there any other upgrade needed? Thanks everyone https://cimg5.ibsrv.net/gimg/5series...9088a4fbf6.jpg https://cimg6.ibsrv.net/gimg/5series...b40e23455f.jpg https://cimg7.ibsrv.net/gimg/5series...d4a0fd379b.jpg https://cimg8.ibsrv.net/gimg/5series...4b2c93e955.jpg |
Beautiful car! :thumbsup: Welcome to the forum.
:welcome: to the group!
Regarding the head unit, what do you want out of it? I personally like OEM so I upgraded to a CIC unit (just for the higher-resolution screen) and then installed a Mr12Volt system for wireless CarPlay. They do make a version for CCC (which you probably have) as well and that would be the easiest/cheapest option. Frankly, I don't think the increased resolution from the CIC upgrade would really even make much of a difference.
Originally Posted by kd7iwp
(Post 1624170)
| All times are GMT -8. The time now is 08:52 PM. |
