M5 on places with high elevation places.
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
After I watched the video taken in South Africa that 335i beating M5 e60 (they says on P500 mode) and it due on elevations... There the elevation is 5500 ft.
Fact or opinion? or M5 driver fails?
Calgary's elevation is approximately 1048 m (3438 ft) above sea level. How affect the M5 power specially with NA on elevations? NA loses 17-20% and FI just 2-3% due the reduced air density on elevations.
What are you talking about?
335 beating the M5?
Sure the 335 gets off the line faster and is ahead for a short time due to the low end torque, but that M5 won,
unless you're talking about the 0-40 race
335 beating the M5?
![](https://5series.net/forums/public/style_emoticons/default/clap.gif)
Ok, I researched it and found an interesting page talking about density: http://www.dragtimes.com/da-density-...calculator.php
Using the calculator: If I do 1/4 mile it gives me 13 secs with that altitude and sea level gives me an equivalent of 12.36 secs that is about ~%5 decrease.... not bad at all then!
My Ride: E60 M5, 2006
E46 318i, 2004
if u check the vid again, i think the M5 driver he was driving the beast with D mode!!! i didnt see his hand moving or changing the pedall!
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
Okay guys.. let me educate you!
1. The M5 driver was definitely in P500 mode, because he used launch control. And when in launch control, the beast shifts automatically for you!
2. If there is one thing the M5 lacks in, it's a stand start performance. I have driven the 335 and it has amazing traction off the line, it's just a slam the pedal thing and it jumps like a frog!
3. Looking at how the M5 overtook the 335 in that video, I will bet that 335 is running a piggy back ECU ( either a JuiceBox or a Vishnu box ).
Here's a video of my M5 from standstill in P400 mode against a 335 running JuiceBox Plus. 2nd run was rolling in P500 mode.
Thanks! but what happens at altitude? NA loses more power than FI. According the air density in Calgary, the NA loses 5% of power (not much). More altitude NA loses more. (If an M5 is in La Paz, Bolivia where the altitude is over 3500 m (~11.500 feet), it loses about 25% of power while FI only 5%).
PelicanParts.com
08-13-2015 01:45 PM
PelicanParts.com
08-04-2015 01:34 PM
PelicanParts.com
07-23-2015 12:41 PM
