M5 Launch control?
Old Feb 25, 2007 | 08:31 AM
antmtl's Avatar
Hey guys, I read on some forums that there is a launch control feature, where you hold down the downshift paddle etc...
I tried doing this (with the DSC off, shift speed in position 6 etc..) but no luck.
Does this exist on the Canadian or US models?
Thanks,
Ant
Old Feb 25, 2007 | 08:45 AM
vegastrashed's Avatar
Yes, but it's been crippled on purpose unlike the European M5s which have the fully functional launch control. For more info go to M5board.com.
Old Feb 25, 2007 | 03:04 PM
bonehead's Avatar
Euro "Launch Control" (clutch drop at 4000RPM's with auto shift at redline) is not available from the factory with this option in the US or Canada. All we get is the 'crippled' version that drops the clutch around 1200RPM's without auto shift at redline. HOWEVER, Turner Motorsports in Massachusettes revealed to us that they can outfit any E60 M5 with Euro LC by doing a hardware/software upgrade for around $6K (I think...). Haven't been any takers on the M5Board that I'm aware of....yet. Care to be the first one?
Old Feb 25, 2007 | 03:09 PM
You know what's interesting is that with the 545/550 SMG, the launch control is exactly like you described for the European M5. Revs to 4000 rpms, dumps the clutch, and automatic shifting.
Old Feb 25, 2007 | 04:03 PM
antmtl's Avatar
Perhaps, what's involved in this upgrade?
However more interestingly, how do I perform the 1200 RPM launch?? I can't even seem to do that...
What's the 'proper' procedure?
Thanks,
Ant
Old Feb 25, 2007 | 05:46 PM
bonehead's Avatar
Probably due to the fact that the drivetrain can withstand repeated beatings with 360 hp/360lb/ft torque vs. 500 hp/383lb/ft.
Here's a link to info on the TMS upgrade
http://www.m5board.com/vbulletin/showthread.php?t=89811
As for our 'crippled' LC: S6 (DSC off), p500S. Level surface, wheels pointing FORWARD, shifter pushed forward (YOU CANNOT INITIATE LAUNCH WITH THE PADDLES!), pedal quickly to the floor past the kickdown position, wait till revs peak, release the lever--->wheels spin, tires smoke, start laughing like little schoolgirl.
Old Feb 25, 2007 | 06:04 PM
After have done a few launches, I've learned that you need to wait at least 5 minutes before attempting another. I have had the launch control disabled after attempting consecutive launches with minimal recovery. The dealership had to reactivate the launch control. I'm sure it's the same way with the M5.
Old Feb 25, 2007 | 07:36 PM
Alex.br's Avatar
My Ride: 2007 E60 M5
Yes the M5 needs to "refresh" too. Also the LC is unlocked only after the first 2.100 km.
Old Apr 2, 2007 | 08:28 AM
JamesInLV's Avatar
One thing we get here in the USA that apparently doesn't work on the Euro version is an "emergency launch" or what I call a "drop clutch start." Basically, the clutch doesn't fully engage until about 7-9mph. If you push the accelerator all the way through the kick-down from a stop, it will rev up to about 3-4k rpm and drop the clutch. Do this with EDC Off, S-6 and you'll never gain traction until you shift. Do it in S-5, and you'll actually get a reasonably controllable launch, although you will probably still have to modulate the throttle to get a smooth and fast start from the line. It's kind of fun doing this from a slow rolling stop, at about 3-4mph if you push it to the kick-down, you'll get a more reasonable rev-up and clutch drop that is very controllable and minimal tire spin.
Don't try any of this with MDM or DSC On...you'll just go bunny hopping until you let off.
Old May 11, 2007 | 08:29 PM
yorgaki's Avatar
Hi everyonne,
Just experienced neck breaking shifting for the first time today....I just had my 1200mi service today and all I can say is WOW!!
Does anyone know of any good strips of road in OC and/or Huntington Beach to use launch control and to really push this beast?
thanks
sxybeemr
Jun 20, 2023 10:13 AM
jcolley
Aug 1, 2016 06:48 AM
lcc014
DIY: Do It Yourself
Sep 10, 2015 05:57 AM
bimmerspeed
Sep 3, 2015 09:29 PM
bimmerspeed
Frequently Asked Questions
Sep 1, 2015 05:09 PM
