FTM warning
Old Nov 19, 2009 | 09:30 AM
Ellicit's Avatar
what's up everone
I was driving on the i95 when I got a FTM
kind of fraked out... so I pulled over and all the tired seems fine?
drive about 15 miles, everything seem find still?
shoud I just reset it the FTM?
Old Nov 19, 2009 | 09:36 AM
Gene's Avatar
I would at least check the psi's to make sure everything is "fine" then recheck it daily to see if there is a dramatic difference....
Old Nov 19, 2009 | 09:39 AM
Ellicit's Avatar
Thanks for the advice
what should the PSI be 3.5?
I'm rolling on the 166M
Old Nov 19, 2009 | 09:42 AM
Gene's Avatar
what did you have them at?
with the 166's I've seen psi's mentioned @
F 32 R 36
F 34 R 38
F 38 R 42
F and R 42
it's up to you....I run my psi's with my 166's @ 38/42
Old Nov 19, 2009 | 09:55 AM
Ellicit's Avatar
F 32 R 36
F 34 R 38
F 38 R 42
F and R 42
I'm not even sure... I really never checked mine since it was installed.
I'm going to check all today and keep it at 38/42
thx
Old Nov 19, 2009 | 10:03 AM
CWS530's Avatar
Could have just hit the threshold psi for the alert. If the temperature has dropped, that may be the cause. I run 38psi all around on my 18s, but as Gene said, it depends. At 19 you have a little less side rubber, so you may want to do 39-40psi in case you hit a pothole.
Old Nov 19, 2009 | 10:59 AM
Ellicit's Avatar
I hope your right... I'm worried when I get out of work and talk to my parking lot jus to find one of my tire is FLAT lol
Vman33
Mar 14, 2022 04:43 AM
derooster
Sep 22, 2015 10:10 AM
Gadamsm5
E60 M5 Discussion
Sep 15, 2015 11:43 AM
bimmerspeed
Sep 3, 2015 09:29 PM
bimmerspeed
Frequently Asked Questions
Sep 1, 2015 05:09 PM
