E60 M5 Fuse Map
oops, there isn't one in the glove compartment of my car..(?)
perhaps someone would be kind enough to check theirs and post which fuse is associated with what, for me
and, while I'm asking, is there 'sposed to be one in the trunk, for that fuse location ?
thanks
thanks
Our fuse box is on the glove compartment and there's one on the trunk right behind the gas tank iirc
uh, perhaps I didn't make my request clear.....I need a chart that shows what each fuse allows to be powered (example: 1st fuse on the left, 7.5amp, reading lights.....2nd fuse from the left, 15amp, navigation, etc.....)
and yes, my car too has a fuse box behind the glove box, and another inside the trunk, right side behind the carpeted panel
anybody ?
anybody ?
See if this one helps off
anybody ?
anybody ?
thanks guys, that's what I was looking for (guess that's as good a place to have it as any other)..
///MFEST : Do you happen to have the bottom part of that PDF ? the Fuse No/Amp listings didn't come up completely (was cut off) on your attachment
again, thank you
(there's a particular fuse that I'm looking for - but I always make a list of my own, with translations - and then laminate it and keep it in the car - makes for easier "fuse finding" should there be a malfunction at a later time)
again, thank you
Here you go (thanks to Dan for the fuse chart)
again, thank you
again, thank you
once again, thanks - somewhat blurred when printed but I'll make it work (I really really love what's been done to the (yellow) car - except for it being laterally stretched in your signature pic)
