Donut on M5
Old 10-02-2007 | 11:38 AM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Thumbs up
I have M5 front brakes(rotors and calipers) and I still have the spare tire(donut) in my trunk. I know the M5s don't have this.
Is it because it will not fit the bigger brake system or just to minimize weight? I don't want to carry it in the car if it's not necessary. Thanks in advance .
Old 10-02-2007 | 02:05 PM
vegastrashed's Avatar
Joe,
I'm sure the spare won't fit your M5 BKK. If you want to use the spare tire in case of a flat, keep a 5mm spacer handy. It'll help to clear the pistons.
Old 10-02-2007 | 03:16 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Thanks Joe
Old 10-04-2007 | 01:38 PM
JamesInLV's Avatar
M5's don't have it for both reasons! The spare tire compartment has a special insert with the mobility assist kit (tire pump and a few other things) as well as the battery. Battery was moved to the trunk for both weight balance and size issues. However, a LOT of M5 owners are looking for a donut spare that would fit the brakes that they could take on vacations without loosing too much cargo room. It sounds to me like you might have figured it out. I may need to find a non-M E60 friend around here to check out the possibility of mounting the donut with a spacer onto my M5.
Old 10-04-2007 | 04:26 PM
jet190rs's Avatar
M5's also don't have the spare tire in order to have a quad exhaust.
Old 10-09-2007 | 11:39 AM
AlexFW's Avatar
Model Year: 2005
Originally Posted by vegastrashed' post='477094' date='Oct 3 2007, 12:05 AM
Joe,
So the spare tire could fit with a spacer ?
It is very sad .. I got nonRF tires thinking "In case of puncture I have the spare tire .." .
In case of front tire puncture I figure I couldn't fit the /275 (would it rub ?) in the front and the spare tire in the rear, right ?
Old 10-13-2007 | 07:13 AM
AlexFW's Avatar
Model Year: 2005
up
Old 10-15-2007 | 06:32 PM
jet190rs's Avatar
huh? why would you not want to put the spare onto the front - where the puncture is...?
Old 10-15-2007 | 07:51 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Because we both have bigger M5 brakes up front. I do think our rear wheels will not fit the front , they're too wide.
I guess we just have to carry the right size spacer for the spare tire to work.
Old 10-15-2007 | 09:20 PM
jet190rs's Avatar
oooh, gotcha
Quick Reply: Donut on M5
