2007 E60 M5 Central electronics module issue
Old Jul 5, 2020 | 01:16 PM
Bradley Tiffany's Avatar
My Ride: 2007 E60 M5
Model Year: E60 M5 2007
Default 2007 E60 M5 Central electronics module issue
I started coding with the Carly adapter a few years back, & I think it finally fried my Central electronics module better known as the control body module. Everything worked fine for a while but then I started noticing things I coded, for example welcome lights turning on when you unlock the car started not working half the time. Then ultimately I started getting a bunch of error codes. Abs, Electronic dampening control, start off assistance, check battery terminals, powering steering went out, idrive screen started flashing on and off. The cluster would glitch and I would be going 60 mph and my speedometer was at 0 mph. The music would stop playing then come back on. The latest thing is my sunroof will only open a little bit at a time. My battery was well overdue to be replaced so I did that. I took it for a a drive and everything was fine for about 30 min. Then it happened again, but only one error msg went off. It didn't give me like 5 different error codes. The sunroof is still only opening a little hit at a time and the music cuts out as well. I ordered a used CEM I/E CMB for my car. I'm trying to find out if there's any programming that needs to be done prior or after i install it. For future coding I will be getting ncs expert to code. Any information from anyone would be greatly appreciated. I also attached some pictures of the error messages I saw. Thank you
Old Jul 8, 2020 | 03:47 AM
speedlimit's Avatar
Admin Emeritus
My Ride: BMW F13 640i M Sport
Model Year: 2015
Engine: 315-hp 3.0-liter
Hi and welcome!
I see you have opened a discussion in E60 forum, thank you for intro!
Bob
Wolfgang009
Nov 16, 2019 11:39 PM
UltimatePeter
Oct 5, 2014 09:14 AM
spngr311
Feb 22, 2012 08:02 AM
525iEnjoy
Lounge
Sep 27, 2010 02:33 PM
chowbox
Lounge
19
Sep 28, 2009 12:33 PM
