09 535xi ///M5 parts upgrade?
Heres my question.
Can I take M5 parts and put them on my 09 535xi, Reason being if i need to replace the calipers and rotors id "like" to use the M5 brakes...? am i crazy? what are ur thoughts? on the brakes..and other item i can/should upgrade as I'd like to do at least 1 track day a year.for fun. thanks CF |
hello there..
we need to meet..:)) i live on the cape cod too...:)) there is $$$$$$$ that u can spend on your car,,,i will show u how ::))) |
Originally Posted by rackhacker9275
(Post 1570294)
Heres my question.
Can I take M5 parts and put them on my 09 535xi, Reason being if i need to replace the calipers and rotors id "like" to use the M5 brakes...? am i crazy? what are ur thoughts? on the brakes..and other item i can/should upgrade as I'd like to do at least 1 track day a year.for fun. thanks CF pull rod and sway bars Rotor and calipers, rear hub need to be replace with the ones on the m5. |
Have you looked into upgrading to slotted/drilled rotors, ceramic pads, and ss brake hoses? Makes a big difference while keeping all your oem xi parts.
I just purchased an e60 M5 rear swaybar for my 2010 535xi Sport! Will be installing it shortly. Also, I bought a set of e60 M5 wheels,....they're going on too once the correct size tires are purchased.
Future plans: Larger FMIC Charge pipe DICs Down pipes,....possibly, but only if I can go with larger CATs downstream! (Car must be able to past emissions in VA). MHD Stage 2 tune Edit: I'm somewhat building the 2010 535 version of the 2018 F90 M5,...but of course, only in 535xi flavor! |
Originally Posted by JMD535
(Post 1595271)
I did it a couple of years ago with one from ebay.
I didn't need to jack the car at all to do. Super easy. |
Thank you. Did the highway ride change and cause the car to ride rougher? It appears to be the same shape excluding the bar diameter increase from 12mm. Is this correct or did it require new Anti-roll linkage?
Get the Dinan rear sway bar. It's larger than the E60 M5 bar.
The M5 was 18mm and $81 dollars on ebay so I figured why not,
I installed H&R springs about the same time so it was firmer all around. It came with links that looked new so I used them. You have to pay to play. I did it on the cheap but it has to be a wee bit better than stock. Do I notice it with my driving? not really. Springs lowering and the bar helped tighten corners. It isnt your cushy ride anymore. |
