would these rims fit...
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Originally Posted by ImAzNUmKaY' post='223982' date='Jan 13 2006, 06:29 PM
i have a maya dls 20x9, 20x10.5 as of right now on my X5 and I was wondering if it is possible to fit those rims on to my 530i...thanks!
I doubt they will fit as the offset for the SUV's and AWD 5 series is different.
The bolt patterns for SUV and Sedan is totally different.. i doubt it will fit..
My Ride: FOR STARTERS I LOWERED THE CAR USING H&R SPRINGS. I CHANGED THE EMBLEMS TO BLACK AND CARBONFIBER ALSO ADDED CARBON FIBER DOOR SILL COVERS. I PUT ON A SET OF 22X9 - 22X10.5 AZA FORGED MYSTIC 2TONE BLACK AND MACHINED WRAPPED IN PIRELLI P ZERO NERO 245/30/22 AND 285/25/22. AC SCHNITZER REAR TRUNK SPOLER. ZENETTI BODY KIT CONSISTING OF A FRONT LIP, SIDE SKIRTS AND REAR APRON. RECENTLY ADDED 12INCH ANNIVERSERY EDITION JL SUB POWERED BY A JL 500X1 AMP IN A CUSTOM ENCLOSURE WRAPPED IN CARBON AND AUBURN VINLY WITH PLEXI. AUXILARY INPUT WITH IPOD ADAPTER.
depending on how thick the mounting pad on the wheels are they will fit. reason being is you would have to have the back pad of the wheels machined down about 10mm each otherwise the wheels will stick out a little to much and you will endup up rubbing. i have lowenhart ld5s with a 20x9 with a 22offset up front an 20x10 with a 25offset and they clear just perfectly. if you have any more questions hit me up. oh yeah all bmws have the same bolt pattern no matter what the models are.
Originally Posted by ImAzNUmKaY' post='224208' date='Jan 14 2006, 10:33 AM
offsets are +17 rear, +14 front..
I have a 28mm offset on the rear with a 9.5" rim running 285/35. They are tucked just inside the fender. The 17mm offset on a 10" rim would probably stick outside the wheel well by a good 10mm.
My guess is that they are not a good fit and are going to stick out too far.
However, since you have the rims and tires, you could have one front and one rear tire removed and just mount the rims on your e60 and see what they look like.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
