Wiring a usb socket to center console 2006 E61
My Ride: 523i Touring
Hi guys
has as anyone wired a usb socket to the center console. I have removed the old phone cradle and would like to mount a usb socket and if possible take the power from the back of one of he cigarette lighters in the back.
any tips would be greatly appreciated
thanks
thanks
My Ride: E60
Model Year: 2005
this should be very straight forward, find a 12volt usb socket that you like that has the red/black (positive/negative) wires inputs, decide on the location of mounting it, you might have to cut or drill an opening to mount it securely, then run the wires to the rear cigarette lighter socket and tap the wires accordingly.
If i remember correctly, it's a thicker green wire with a white stripe. And it should mate up to the center location of the cigarette lighter connections.
The ground wire is red and a white stripe, and it mates to the outer body of the cig. lighter socket. The color of wires may be different on your car, so best to get a volt meter and verify.
Do a search on youtube to find videos on how to remove the rear trim so you can access the cig. lighters.
This one is in spanish, but at least you get to see the process on how it's done.
My Ride: E60
Model Year: 2005
ahhh, I just read, taking power, was assuming he wanted to add on a usb charge port......to get signal to headunit, I'm not sure.
Administrator
My Ride: 09 535xi Touched by TURNER
Model Year: 2009
Engine: n54
i just did this Super easy but wait thiers more...
Hi guys
thanks
thanks
the same principle will work elsewhere i think I may do my cig lighter
FIND A ROUND usb... remove the 12v socket... POP IT OUT... POP in 12v usb, on the back-side... POP the 12 volt socket back on ... and replug back into OE plug. Reinstall if you need pics let me know looks factory with the flap and all... took 20 min i used hot glue to hold it together DONT BRAKE THE PINS that hold it into the dash...
My Ride: 2004 545i
Model Year: E60 2004
Engine: 545i / N62
I purchase a 12v converter to USB on ebay. I powered from the passenger's footwell power source but you can powered from the cigarette lighters in the back. Wiring you need to figure out.
This will not get any signal to head unit at all. Don't think is possible. Just a power source.
545iMike
07-24-2013 06:59 PM
545IblupasdU
10-31-2012 09:45 AM
Slime
10-11-2008 05:48 AM
