Hi. Can anyone help me understand this WDS i found. I marked the picture with red which is the part that i need to understand. From what i see is that i have the 58G GR/RT cable that is going to be connected to the light module. Is it going to be connected to pin 43 on "plug" X12 or am i wrong?
And the K_BUS SW cable is going to be connected to pin 2 on X276 or on pin 2 on X10116?
And where can i search for the "plug" so i know which one im looking for?
Engine: N54
Is it going to be connected to pin 43 on "plug" X12 -- Correct
X275 is the same plug for the question above. So pin 3 from the switch will be pin 2 in the plug. Pin 4 from the switch will be pin 23 on the plug X275 which goes to pin 43 on plug X12 for module A3.
