Winter wheels tires question
Old 01-01-2009 | 06:17 AM
smimhee's Avatar
I can put 17inch x 8inch rims right?
Can I put 15mm offset rim?
Please advice me ASAP!
Thanks
http://www.discounttiredirect.com/direct/f...d=17&cs=225
Old 01-01-2009 | 06:27 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Thanks
Yes you can!
My winter setup is 17x8 ET20 and I'm running them with 5mm spacer front and 12mm rear, so the "final" ETs are 15 in front and 8 in back.
edit: Oh, just be sure about right sized tires !
edit2: About those Beyern wheels. They look great, but I don't think you're going to have much lip with 8" wide ET20 wheel. Just a thought though...
Old 01-01-2009 | 04:32 PM
smimhee's Avatar
So I do need spacer for this rims?
By the way, my car is 545i with sports package.
I just want to buy 17inch rims + winter tires (direct installation, no spacer no mods)
tirerack.com's cheap winter tires are all sold out.
Originally Posted by Anzafin' post='757089' date='Jan 1 2009, 10:27 AM
Yes you can!
Old 01-01-2009 | 06:43 PM
545felix's Avatar
My Ride: 05 545/6
make sure you select your 545 as the car in the tire rack wheel selector and you should be fine. the non-sport 545 comes with 17s so there has to be some that fit.
Old 01-01-2009 | 11:10 PM
Anzafin's Avatar
No you don't need spacers with them. I just tried to tell that ET15 is ok, and even smaller ET numbers are acceptable in rims of that size.
17x8 ET15, 5x120, hub 72,56mm will be a perfect fit with your car.
About that hub. If it's 74,1mm, you will need hubcentric rings.
blackstarr
02-13-2016 08:34 AM
srogers535x
14
04-26-2015 09:39 AM
jglaze
04-13-2015 07:54 AM
bestofthebest
03-30-2015 08:12 PM
08-12-2003 11:41 AM
Quick Reply: Winter wheels tires question
