Will my OEM 123s fit on a e90?
The offset on the standard 123's are ET20, per this link:
http://www.realoem.com/bmw/showparts.do?mo...hg=36&fg=15
The offset on the E90 wheels are ET34 (ET37 in the rear, if you go with the staggered's), per this link:
That all being said, I believe the 123's would work, however you would need spacers. I believe the hub ring is the same size too, but that I'm not certain of. The only reason I say that it is, is because I have the M3 CSL wheels on my car and they are on most of the E90's on VelocityMotorings site. I didn't have to use hubcentric rings. It was a perfect match.
SFx550i
04-14-2015 05:00 PM
bapeforceone
03-11-2015 04:18 PM
