Will M5 brakes fit under Style 124s?
My Ride: 05 545/6
Does anyone know if the M5 front brakes will fit under Style 124s? I want to upgrade but learned to check this first the hard way last time on my E39.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Doubtful. Most people here who have retro-fitted M5 brakes on their e60s also have the OEM 166 wheels. Two members who have M5 brakes on their e60s are rizbel and AlexFW.
Someone says no. Try! If they don't fit you will have to order 166, 167 or 172 19" wheels .
The only thing I know is the spare tire doesn't fit anymore and I have to get some 12mm spacers .
My Ride: 05 545/6
From RealOEM.com link it listed M Style 184 wheel as M5 winter wheel option, same size as Style 124 (8"x18") BUT different offset so not sure if 6mm difference is to clear the brake caliper or not plus the spoke design may play in role too.
You would need a M3 front wheel which is a 35mm offset on a 18x8 then add a 12mm spacer then they might fit, I remember using a stop tech template on my old rims and they did fit.
Too much math just get 19's or 20's with correct offsets.
