Will F01 7 series wheels fit e60 535i?
My Ride: 2008 bmw 535i black sapphire metallic w/ tan interior , sports package , premium package , parking sensor, shades,usb , HRE 20's, CKS C1's coilovers, rpi scoop, OEM M5 side mirrors,OEM Gloss black kidney grills, ACS roof spoiler, ACS Trunk spoiler, 15% madico tint all around..
NEXT UP: bodykit and quads ( installing soon)
cobb
Anyone knows if f01 (new 7 series) wheels be compatible with e60 non m? I did a search and found that bolt pattern is the same, and center bore is the same, but offset is higher on rears, will putting spacers fix this? has anyone has done this before?
cobb
F01 Bolt Pattern: 5x120
Center Bore: 72.56
Hardware:14x1.50 Bolt ( for e60 it says 12x1.50? will this be ok?
Offset:
Front: 15-25mm
Rear: 32-40mm
as for the wheels... i think there 9 and 10.5-11? not sure
Center Bore: 72.56
Offset:
Front: 15-25mm
Rear: 32-40mm
cobb
soo they will fit? its just a matter of wheel width and exact offsets?
My Ride: 14 550i
No I'm not saying they will fit. We need the exact offset and exact width to be able to tell you if they'll fit. When you say
Front: 15-25mm
Rear: 32-40mm
That's a range of 11mm in the front and 9mm in the rear which is HUGE. That's why I am asking you for the exact offset and width.
Front: 15-25mm
Rear: 32-40mm
cobb
i think they are 9.5 to 10 front and 11 rears no info about offsets =(
cobb
is there anything I can do to avoid rubbing with 10's in front? they could be 9.5 but not sure.... also just guessing i think front offset 30 and rear 24
My Ride: 14 550i
You'll probably need to pull the fenders instead of just rolling the fenders. Not worth it in my opinion just get something that fits properly instead of devaluing your car with fender pulling.
