Will e39 wheels fit the e60?
Originally Posted by jd604' date='Apr 4 2005, 03:39 AM
Hi guys/gals,
Quick question... will the wheels from my e39 fit directly onto the e60 without modification or need for spacers or use of The Force?
Thanks!
Thanks!
[snapback]110800[/snapback]
It should fit.. they have the same bolt pattern.. and i think the offset has a difference of 2mm..
My Ride: 545i Mystic Blue/Black Leather Type 124 Wheels
On the E39 for 18" wheels BMW uses front offset ET:20 , rear ET:24
On the E60 Front ET:20 rear ET:32
These are for 8J front and 9J rear rims
Originally Posted by Merv the Derv' date='Apr 4 2005, 03:52 AM
[quote name='jd604' date='Apr 4 2005, 03:39 AM']Hi guys/gals,
Thanks!
Thanks!
[snapback]110804[/snapback]
[/quote]The Style 135 for the 3 series Saloon and coupe have totally different offsets from the ones for the 5 Series
My Ride: 2005 MY 545i Sport Saloon. 2006 MY Alpina B3S Convertible. 2006 MY Brabus Smart 42 Cabrio. 2006 MY AM DB9 Coupe.
E60Speed is absolutely right! The 135s on E46s that you see are NOT the same as the 135s on E60 Sport models! I know someone in the UK who thought they were, ordered a set because it was 'not so expensive' and wondered why they didn't work on his 530! The 135s for the E60 are now available as an extra.
Thanks for all the responses guys
Now I'll have to check if the rims I own are 8J front and 9J rear... I think I remember the guy having to put hub rings to fit them at the time of install but not sure if that's a good or bad sign.
