Will dealers install Xenon headlights?
I have the 2004 Halogens which look kinda crappy, so I've decided to upgrade the headlights to the 2004-2007 pre-LCI xenon headlights.
As I understand there are a few things to be done, i.e. retrofit cabling, new light modules, reprogramming?
My question is that, if I just give my dealer two headlights, ballasts and bulbs, are they able to supply the rest of whatevers necessary to get the lights up and running?
If anyone has done something similar with their dealers, how much did it cost you just for the installation and parts? (excluding original costs of headlights)
My Ride: 05 530i
87 325is
85 VW GTI
Take it to a local shop. They should be able to install it no problem. You might have to sign your life away first to get the dealer to install them.
They will do the install but I don't recommend it. Take it to an Indy shop to have it done. You may end up back at the dealer to have the car reprogrammed however.
The dealer is going to TELL you that you need a new LCM and new cables and will probably charge you over $5,000...that is assuming they tell you it can be done. I called three dealerships and they all said it couldnt be done. After searching this forum and reading different posts, I was able to do it .
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
550iwa
03-27-2015 06:45 AM
