WILL ALPINA 21" FIT ON MY E60????
21" OEM style 128's fit on e60's, and those were made for the 7 series as well....post the offsets of the alpina wheels just to be sure...
Originally Posted by alpina04' post='885689' date='May 21 2009, 01:51 PM
Will the B7 wheels fit with no problem on the 5?
ok, they are 9X21front and 10.5X21back
uses the M14X1.5 bolts, so I'm assuming those are 14mm long bolts, which would theoretically put the offset at somewhere between et15 and et20... that said, I'm just guessing here...
This is the realoem.com link for the rim, but I can't find offset info on there...
Now, B5 S "Standard" wheel is 20 inches - 8.5front and 9.5back with 245/35 ZR20 and 285/30 ZR20 tires, respectively.Aplina B5 S specs HERE Which means that you probably will not be able to run 21s with a reasonable profile-sized tires. You most likely will also need modifications to the suspension to erradicate rubbing issues.
But it'll look badasss
bestofthebest
03-30-2015 08:12 PM
