will 21" 128's fit help offset guru's
Originally Posted by olli_535d' post='431782' date='Jun 4 2007, 02:35 PM
Do you mean rubbing on the struts or on the arches ? If rubbing on the arches is meant, then spacers will push out the wheel further and increase the rubbing.
The offsets are perfectly fine for the E60. The closest you can get to stock rolling dia and circumference would be by using 255/30/21 and 295/25/21
These will still be just over 4% out, but comparable to the oversized 20" combo many on here drive in terms of size. the sizes you mention would be about just under 8% out and certainly not be really safe.
245 front and 285 rear with these aspect ratios would be better, but I have never seen these sizes in 21"
They will fit, but the question really is if it is worth the hassle. Not only are 21" mightily expensive, but 21's will also be an absolute killer to your ride, as they will massively increase the unsprung weight and make it very bouncy in handling terms.
But just the wheel and offset parameters are a perfect fit for an E60.
thanks for the write up my decision is still up in the air .. and comtemplating all these facts... i know people go 20" and ive even seen 22" asanti's on e60's with no problems is there something different about stock wheels in 21"s than aftermarket 21"s that im missing here.. because i think that lowering the car a bit would make it look fine and not give it a 4x4 look.. then again how low i can go without rubbing or other problems ect im not sure. 1 reason i really want to do is NO one else has them (but then again theres a reason no 1 has them) maybe i just need to be the guinea pig and if it looks good and works out maybe more e60'ers will try these.
Originally Posted by xexyus' post='431805' date='Jun 4 2007, 04:09 PM
Yea I meant 245 30 21
245 35 21 will ride super high and I doubt it will fit.
here's this guys tire size combo F 245/30/22 - R 285/25/22 i dont however know his offset but u guys are telling me the offset shouldn't be a big deal.
here's his car.. tell me what u guys think.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
I believe that is Wheelzplus' ride. We are saying you would look like a 4x4 with the tire sizes you initially mentioned: Front: 245 / 35 / 21, Rear: 285 / 30 / 21. Both xexyus and I said that 245/30/21 and 275/25/21 or 285/25/21 will be okay. I don't know if there will be room to lower the car but you can try.
ohhh ok got ya..... i though that comment of 4x4 came more from just being 21"s not tire sizes.. ok so bassically 30's in the front and 25's in the back will do it. if it is wheelsplus hope he dosent mind his pics as reference .. but he's lowerd on H&R sport springs and those where going to be my choice of springs in the 1st place so me lowering it should look very similar to him if i go thru with this.
ok reason 1263456168741 for me to get the 19"s searched tirerack,discounttiredirect, and other sources for these sizes 245/30/21 275/25/21 or 285/25/21 and came up empty.. no tires found.
looks like this is gonna be harder than i thought i should just get the 19"s.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: 05 530 Titanium Silver/Sexy black
Its a rare tire size but I believe Pirelli and Michelin makes that. I wouldnt do 19s for sure, if anything 20s and up. Im sure you would definitly regret doing 19s if your looking at 21s. And as far as ride quality, its all the same in all honesty. Ive had 19 and ive had a bunch of 20s, same ride.
ok heres the verdict these are the only tires i could find in 21" 295/25/21 and 255/30/21
here's a car stitting on 21" lowenharts with these tires. i have no idea what his offset is but im assuming if the offset isnt a problem this is more or less how the car would look. what do you guys think should i go for it or get 19"s??? im still undecided.
