will 21" 128's fit help offset guru's
I really like the 128's and wondering if I can somehow get away with putting the 21" version for the 7 with some specific tire size..istead of getting the 19" version ,not sure if this has been attemted before but thought id ask, here are the specs...
Front.. 21x9 , 22MM Offset
Rear... 21x 10 , 25MM offset
and also these tire sizes..
Front: 245 / 35 / 21
Rear: 285 / 30 / 21
Rear: 285 / 30 / 21
My Ride: 2007 M6 Coupe
Sapphire Black/Black Merino
Loaded
Rear: 285 / 30 / 21
Rear: 285 / 30 / 21
I like the style but think the offsets are all wrong. I initially ordered these with my E63 but when it arrived the dealer received a memo from BMW corp to not install them on the E63. I would imagine that the same would hold true for the E60.
thanks for the, dang that sucks i figured it would be a long shot but .... can any 1 else chime in on the subject???
My Ride: 2004 545i, 1995 M3
Rear: 285 / 30 / 21
Rear: 285 / 30 / 21
Check HERE and HERE to see some tire size info and calculators.
I think with a little bit of work you could get these wheels to fit.
Bill P
Originally Posted by Bad Bimr' post='431667' date='Jun 4 2007, 08:12 AM
The offsets are off but not by much (about 2mm front and 3mm rear) . If rubbing occurs the offsets could be adjusted with the use of spacers. The bigger concern is tire size. The size you mention are ~2.1 inches taller then stock. Without other suspention mods, I think the car will look like a 4X4 with this setup. The tire size will also throw of you mph by 7.9% to slow (you indicated 60 mph will actually be 64.7 mph). The taller tires will change you final drive and make the car slower but top speed higher. The good news is the after driving 10000 miles your odometer will only show 9267 miles (good way to keep miles off your car).
Bill P
Bill P
thanks for your reply that tire size calculator link is helpfull... i think im leaning towrds the 19"s since it seems its going to be less of a headache fitting them and 21" tires arent that cheap. i am definetly going to lower the car regardsless of which size i get but ive never seen the 21"s on an e60 lowerd i think it'll look good.
Originally Posted by xexyus' post='431688' date='Jun 4 2007, 09:38 AM
Im pretty sure it would fit with no problem as long as you can get a 345/30/21 in the front. The offsets seem ok
wow 345's in the front.. i dont think so... i thought i could use Front: 245 / 35 / 21 those tires fit on the rim's.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
xexyus obviously meant 245/30/21 for the front and I agree. I also agree with Bad Bimr that if you choose to go with 245/35/21 and 285/30/21, you'll be riding as if you're on a 4X4.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
Bill P
Bill P
The offsets are perfectly fine for the E60. The closest you can get to stock rolling dia and circumference would be by using 255/30/21 and 295/25/21
These will still be just over 4% out, but comparable to the oversized 20" combo many on here drive in terms of size. the sizes you mention would be about just under 8% out and certainly not be really safe.
245 front and 285 rear with these aspect ratios would be better, but I have never seen these sizes in 21"
They will fit, but the question really is if it is worth the hassle. Not only are 21" mightily expensive, but 21's will also be an absolute killer to your ride, as they will massively increase the unsprung weight and make it very bouncy in handling terms.
But just the wheel and offset parameters are a perfect fit for an E60.
