white led halos?
i have a 2006 e60 525i and i havent been able to find a set of halos that fit my car, can anyone send a link or send me in the right direction
Apply yourself, do some research... this is far and away the most common question since 2007-2008. You can search practically anything and find a plethora of answers regarding angel eyes.
But regardless, try some of these search terms. Angel eyes, Umnitza, Mtech, Lux, Depo Also, learn the difference between pre lci and lci cars. Yours is 2006 so 99.9% it's pre lci. And i'll spare you the experience of being lied to by led bulb vendors, your car won't use anything greater than 10W bulbs should you choose to go a plug & play route. |
Originally Posted by justalilbit
(Post 1556649)
Originally Posted by wrx5
(Post 1556702)
What is the max Watt for LCI cars?
(Post 1556715)
Not sure, but I would anticipate it to be significantly higher than pre LCI.
OEM bulbs will produce 10% light and 90% heat. so 10w x .1 = 1w LED bulbs will produce 60% light and 40% heat. so 20w x .6 = 12w |
You can run the 128W ICETEC on your car without any issues.
it's very bright and well put together. |
Save your money and install V2's or V4's by Umnitza. you will be happier in the long run.
