White bulbs for DRL/HighBeams on Pre-LCI
Old 10-06-2008, 11:01 AM
VirtualRain's Avatar
My Ride: 2006 M5
Hi, I'm going to get the Trinity Mycarr AngelEye lamps but I want to also update the bulbs for the DRL/HighBeam lamps (closest to the grill) to something that matches the HID's.
Has anyone swapped these bulbs? What bulbs did you use? Any pics?
Trinity is suggesting "Cosmic White" Japanese bulbs.
Thanks for your input!
-Chris.
Old 10-06-2008, 02:02 PM
Nick@Jlevi SW's Avatar
Hi Chris,
We have had a lot of success with the Xenesis Tru Match Bulbs which are a direct replacement for your DRLs and Fog Lights. They are a good match to the MyCarr units and your stock xenons to provide a more pure white light output.
Old 10-06-2008, 02:26 PM
My Ride: 2006 M5
Originally Posted by Nick@Jlevi SW' post='686753' date='Oct 6 2008, 05:02 PM
Hi Chris,
Has anyone here actually done this mod? Pics?
Old 10-06-2008, 11:43 PM
My Ride: 2006 M5
Has anyone used these HID kits for DRL lamps? Do they work ok in DRL mode (which I believe uses reduced voltage)...
http://forums.e60.net/index.php?showtopic=53902
Old 10-07-2008, 05:09 PM
bigscore's Avatar
My Ride: 05 645ci Steptronic, Sport & Cold Weather Package, Black on Black with Blackwood Interior, PDC, Illuminated BMW Door Sills, Logic 7 Sound....Mods and pics on the way !
Originally Posted by Nick@Jlevi SW' post='686753' date='Oct 6 2008, 06:02 PM
Hi Chris,
Just so i dont screw this up.....Are you saying the Fog bulbs will fit the DRL's ?
Old 10-07-2008, 05:45 PM
My Ride: 2006 M5
I believe the DRL's use an H7 bulb... not sure about fog lamps. At any rate, I'm sure Xenesis or any other manufacturer makes a full line of bulbs that would fit any application.
I also understand that the HID upgrade I mentioned above will not work for DRL's because DRL's use reduced voltage to the high-beam lamps and would not provide the necessary voltage to the HID ballast for them to work properly.
Old 10-16-2008, 09:09 PM
JETBLACK530I's Avatar
My Ride: 2004 jet black 530I, M-tech body kit, ac shnitzer roof and trunk spoiler. kelleners sport exhaust and pully kit on its way from germany.
do the high beams give error codes if you replace with aftermarket h7 bulbs.
Old 10-16-2008, 09:35 PM
navin's Avatar
My Ride: 2005 545i
I have the comic white ones i got from trinity, not bad for the price. I doubt you are going to get any brighter because of the reduced voltage.
The only problem i have with them is that the tips of the bulbs are blue so the drl housing reflects blue when they're off.
Old 10-17-2008, 10:28 AM
Thabks man, but i want to get yellow ones. I want the housing to refelct yellow once off. I was wondering if i replace them will there be an error.
Old 10-17-2008, 12:21 PM
Your fogs will use a different fit/bulb type but they are the same essential bulb in terms of color and output. If you are unsure if your bulb type, check out Sylvania's replacement guide or give us a call
Quick Reply: White bulbs for DRL/HighBeams on Pre-LCI
