where to find headlight lens or cover for e60 headlight
What part on here do you believe is broken? http://www.realoem.com/bmw/showparts...18&hg=63&fg=05
If it is just the lens, would sealing it up help instead of replacing it? As far as I know the lens is fully "built" in and would require changing the entire headlight. But I could be wrong, just basing this from what I learnt on here and the diagram.
If it is just the lens, would sealing it up help instead of replacing it? As far as I know the lens is fully "built" in and would require changing the entire headlight. But I could be wrong, just basing this from what I learnt on here and the diagram.![Roll Eyes (Sarcastic)](https://5series.net/forums/images/smilies/imported/rolleyes.gif)
THANKS FOR THE INFO, BUT THE LENS CRACKED ON THE SIDE AND THE RUBBER SEAL IS CRACKING THAT SUPPORTS THE LIGHT.
milhouse4u
04-22-2015 04:43 PM
kurtb23
04-22-2015 04:30 PM
