Where can I buy CCC Fan control Cable/harness
My Ride: BMW 2004 530i
Retrofitting 2007 CCC unit into 2004 BMW 530I :::: Need fan control cable desperately .
Raymond
516-348-3324
Raymond
516-348-3324
Did you look around in your car with the module out? Often on the older models they were tucked inside waiting to be discovered... It's very possible that you already have it there.
Thanks for the quick reply . Yep .. The module was out and I looked for extra cables . GPS and Fan Control specifically . I will take a second look just in case .... Thanks !
You don't have the cable installed, I am 100% sure.
I've made that retrofit and I made the cable myself by using old connector which I shaped so it can get inside the C block (if I'm not mistaken).
DavaiLave
08-02-2022 02:16 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
