Wheels fitment
Originally Posted by mlist84' date='May 3 2004, 12:20 PM
hi guys, im planning to put breyton magic from my E46 to my new 5. Anyone knows if they gonna fit without any spacer?
thanks in advance.
thanks in advance.
make sure your offset is correct and note that you might need a 10mm or 12mm spacer if you want it stick out a little more. reason being the drive hub on our 5s are deeper and you'll also want to make sure it clears the calipers. check out tirerack.com and talk to a professional. i always do when a customer is unsure. good luck & post up pics.
