Wheel spacers for style 92 wheels?
My Ride: E60 530i, Dynamic Drive, Xenon, Active steering, Navi Business, 17 inch 122, comfort seat, active seats, professional telephone, PDC, Logic 7, 6 CD box., probably the oldest E60 in the forum registered BMW in Munich marts 2003.
Hi,
I?m thinking of buying and mounting a set of 19? style 95 wheels on my E60. However, I?m not sure that they fit readily or if I have to mount some spacers. In short the clearance to the strut housing will be 17 mm less in the front than on E60 wheels. The rear should not be a problem. Do I need spacers and if so, could I just mount them in the front and how wide should they be at a minimum? Any considerations before installing spacers? What is the size (ET and width) of various aftermarket wheels that you have mounted?
The details
The 95 style is made for the 7?series wheels have different ET, ET24 front and rear, width, 9? front and 10? rear, whereas the E60 19? is 8? wide front ET20 and 9.5? ET32 rear (e.g. style 128) . Mounting the style 95 it will result in 17 mm less clearance from the strut housing to the inside of the wheel. In the rear the clearance would actually be 2 mm more than on E60 wheels.
The details
My Ride: 2004 525i Jet Black on Grey Interior---
Tint: Sides 20% Rear Windshield 5% Front Windshield 35%
Wheels: Zenetti Five's 20" by 8.5(front) 20" by 10(rear)--
Tires: Pirelli Asimmetrico 245/35/20(front) 285/30/20(rear)--
Body: Hamann Full Front Spoiler, Rieger Side Skirts, Rieger Rear Apron, AC Schnitzer Trunk Wing
Interior: AC Schnitzer Pedal Set and E-Break
Springs: H&R Sport Springs--
Audio: 2 12" Kicker L7's with a Rockford Fosgate 1501bd Amp With Custom Trunk Enclosure
SOON TO COME:
-M5 Mirrors
-M5 Trunk Finsher
-Brembo GT Big Brake Kit
-Hamann 6 Series Front Spliter Molded
-Hamann Roof Wing
-Full Custom Sound System with TV's
Wow I actully really like the 7's wheel on that 5 it looks great...I don't think you would have any problems with those wheels..you could put spacers if you want but i don't think with those wheels u wold need it..
My Ride: 525dA LCI 08, space grey, M-tech, Advantage, Comfort, Nav Pro 8.8, voice, black dakota, seat heating front and back, active steering, comfort access, comfort seats, glasroof, auxiliary heating, head-up, night vision, bluetooth, DVD multimedia package in backseat, satin chrom, auto headlight control, PDC, adaptive headlights, CDC, HIFI, remaped 240hp 500nm
Originally Posted by Lomag' date='Jun 19 2005, 11:24 PM
If you do need/want spacers, I have a pair of H&R 15mm spacers which I ordered for the rears of my car but ending up using 20mm's instead.
[snapback]140992[/snapback]
Did you change your bolts on the backwheels or did you use the original ones for the 15mm spacers?
Yep! You need longer bolts regardless of the size of spacer you get. Those 5 bolts are the only thing connecting the rim to the car and when going 80+ mph you want them to be secured!
TroyE60
05-30-2019 05:01 PM
bestofthebest
03-30-2015 08:12 PM
