Wheel spacers
My Ride: 2004 525i Executive
I was wondering, is anyone using an sort of wheel spacers? something like a disk spacers, hub rings, hub centric adapters etc.
i was thinking of getting a pair on the rear wheels but i was told from the tyre specialist it would make the ride less comfortable and the wheel could fall off! (for any sort of wheel spacers).
can someone comfirm this? thanks !
You don't mean hub rings. You are talking about spacers which are the discs that push out the wheels. And if you get the extended lug bolts to secure them, your wheels won't fall off.
Your ride quality should not be affected as long as you get hubcentric spacers by H&R, Rogue, etc. You could experience some vibration if they are not. And even if they are, some folks still get vibration, esp. up front & if they are too wide.
My Ride: Mini Cooper
If you are on about the 15mm wheel spacers at the real.
Then it is 100% OK BUT get a custom fit 1 and not the pre cut 1s.
The pre cut will not fit right and there will be vibration in the car.
As for the wheel falling off you will need longer nuts to hold the wheel in place
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Originally Posted by ivan545' post='837633' date='Apr 6 2009, 05:45 PM
i use H and R spacers, 12 mm , paid 92 dollars for it.
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
Originally Posted by pdawg74' post='838402' date='Apr 6 2009, 09:26 PM
I got my spacers from rogue engineering, they also supply the appropriate length lugs for each set you get.
