Wheel Spacers
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
How are wheel spacers bolted on? Does the spacer get bolted onto the hub first, then the wheel bolts onto the spacer?
Or, Does the bolts go directly through the wheel, through the spacer and onto the hub?
Not sure how this works, as I plan on getting spacers, but I would like to know if I can use my current wheel locks or will I need to get special wheel locks for the spacers?
Thanks.
Thanks.
Bolts go directly through the wheel, through the spacer and into the hub. Hubcentric spacers will fit onto the hub itself and have their own lip for the wheel to fit into.
Typically hubcentric spacers will sit in between the wheel and the hub itself and be bolted into place with the wheel. Make sure to use longer lug bolts when you install the spacers.
Mods:
Engine Mods:
Added Electronics:
Shoes:
New Shoes:
^_____________
Retired
______________
any one know where to get wheel locks for wheels with spacers? If so, how much$?
Thanks.
Thanks.
It depends on the size and type.
If the spacers are wide enough (20mm and wider), you can get the type that bolts to the hub. The good thing about going with this type is you can use your stock bolts to bolt your wheels to the spacers. The stock bolts have a very specific look to them (black, with dished heads). Matching these is not easy at all if you need to go aftermarket.
![](http://www.hrsprings.com/images/products/trak_photos/dra_medium.jpg)
For spacers under 20mm, you cannot get this kind. You'll need to go with longer aftermarket bolts (probably with flat heads, but at least black).
![](http://www.hrsprings.com/images/products/trak_photos/dr_medium.jpg)
So what width are you looking for?
