Is wheel spacer needed?
My Ride: Bmw 530d 2004
Ok, I'm running the 8.5" wheel in front as well and its offset is 14. It sits pretty flush.
With a 35mm offset your wheel would sit 21mm inner in a wheel arch than mine. You would have also 21mm less inner clearance. I don't know would it rub the strut, but at least it would look a bit silly. You could use 10mm - 20mm spacer in front.
On the rear axel I have the 8.5" ET14 wheel as well, with a 12mm spacer, and it sits pretty flushed also. With some calculation, your wheel would retract 20mm and would have 46mm less inner clearance, compared to mine. Again, I don't know would it rub the strut, but again it would look silly at least. So, you could use 20mm spacer in rear.
I hope this helps.
- Antti -
I hope this helps.
- Antti -
I hope this helps.
- Antti -
I hope this helps.
- Antti -
chadillac2000
42
09-13-2017 11:15 AM
