WHEEL PROBLEMS
I HAVE AN 06 525I AND PUT ON A SET OF 20'' TORK ICONS WITH HUBCENTRIC RINGS
I'M GETTING ALOT OF VIBRATION IN THE STEERING WHEEL FROM ABOUT 40 MPH TO 60 MPH AND ITS PULLING TO THE RIGHT
I'VE ALREADY HAD THEM BALANCED TWICE AND CAN'T SEEM TO GET THEM TO RUN RIGHT
WOULD I JUST NEED AN ALIGNMENT, AND IF I DO GET ONE, DO I HAVE TO GET IT AT BMW OR COULD I GET IT DONE AT A LOCAL SHOP
My Ride: 545 SE Auto in Black
have u tired the car with the stock alloys do you still have the same problem? if so then its something else causing the problem, if not then check the hub centric spacers that you have by that I mean the plastic which sits between the inner wheel and the hub is one missing?
Tracking can be done at any proper tyre place with a laser 4WA
also turn you cap locks off buddy!
I've had these things on and off 3 or 4 times already and no one can seem to figure out why this is happening. I originally had plastic rings on there and they melted and cracked because they were the wrong size.
My Ride: 05 530i
87 325is
85 VW GTI
Originally Posted by rflannery' post='719217' date='Nov 12 2008, 11:14 AM
Put the stock wheels back on and only have a small amount of vibration at high speeds. Nothing like it is now. Right now my wheels is moving side to side at about 40 to 60 . no wheels locks on there and the hub centric rings are aluminum so i know they didn't crack or melt
![Cool](https://5series.net/forums/images/smilies/cool.gif)
Originally Posted by tbal' post='719900' date='Nov 13 2008, 04:43 AM
-Bent wheels
-Bad alignment
-Bad wheel balance
Either of these or combination of these could be the culprit.
-Bad alignment
-Bad wheel balance
It's gotta be one of those or a combination.
My Ride: Mini Cooper
I also had a very little vibration at 100km and I took my front off and put 2 ring of tape around the hub and then fitted the wheel back on and now no vibration at 100km.
bestofthebest
03-30-2015 08:12 PM
