Wheel offset for Dummies
My Ride: 2004 545i 6speed
Can anyone explain in the simplest of terms what the wheel offset numbers are about, and what implication they have for swapping out other rims on our E60's ???
Specifically, I'd like to acquire the new ///M wheel style 166 when they become available, as they look hot and are a bit bigger than the style 124's I've got now. At 19", I figured I wouldn't have to worry about wheel well rubbing or suspension alteration and the like. However, the specs on the 166ers note front/rear ofsets of ET12/28 while the ofsets for the 124's are ET20/32.
Thanks...
Thanks...
My Ride: 545, Auto, Sport, L7, Pdc, Sunshades, Silver Gray/Black, 19x8.5/9.5 Monet Wheels, Michelin PS A/S Tires, Full M-KIt, B&B Exhaust, 20% Llumar Tint
Here's a wheel offset calculator that I have found useful in the past / Punch in existing width and offset and the same for the new wheels and it'll tell you exactly what the difference will be
Wheel offset calculator
Originally Posted by ch7656' date='Jan 8 2005, 11:18 AM
Here's a wheel offset calculator that I have found useful in the past / Punch in existing width and offset and the same for the new wheels and it'll tell you exactly what the difference willl be
[snapback]77086[/snapback]
I dont want to be the guy having to turn my new BMW ///M wheels into a coffee table (like we witnessed on ebay a month or so ago) !!!
Originally Posted by JBOO' date='Jan 8 2005, 11:35 AM
If you get the wrong offset, the face of your wheels can either be too far out from the side of your car or too far in.? Hope that makes sense.
[snapback]77093[/snapback]
What are the general tolerance limits (how much closer can the rim get to the central hub, or extend outward, before being a problem) ???
Thanks...
Originally Posted by Gizmo' date='Jan 8 2005, 05:47 PM
Thanks... The calculator doesn't take into effect the wheel height differences - how might that influence things ???
Increasing the offset will cause the wheels to be inset more and decreasing the offset will make them stick out more. An increased offset can be fixed with spacers but a decreased offset cannot be adjusted.
A few mm each way probably won't make a huge difference but anything more than about 5mm could make a big difference.
Don't forget, wheel offset can also affect brake caliper clearance as well. Most reputable mfr's of wheels offered for specific applications will know and plan for clearance even though they may be offering an offset that differs from the OEM wheels.
asinner
05-06-2015 06:03 PM
