Wheel Fitment
Hey All. Need some advice regarding changing wheels. Im looking to get some wheels in 18x8.5 ET38 all around. Stock wheels are 16x7 ET20 so ill need some 20mm spacers. My question is what tire size will i need and will i have clearance issues for the front? Thanks.
You have a rear wheel drive car, right? So you should look for wheels with ET20 offset.
Also, google "offset calculator"
![Winkcool](https://5series.net/forums/images/smilies/imported/winkcool.gif)
My Ride: Bmw 530d 2004
Originally Posted by v_therussian' post='906593' date='Jun 10 2009, 12:52 PM
Offsets work the other way around - ET18 + 20mm spacer = ET38. So those ET38 wheels will probably not fit even without the spacers.
Also, google "offset calculator"![Winkcool](https://5series.net/forums/images/smilies/imported/winkcool.gif)
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
The op is right he needs 20mm spacers for ET38 wheels.
My Ride: F11 -14
Anzafin is correct. ET (EinpressTiefe) is a measurement of how big the offset is between the centre of the wheel and the wheel mounting surface.
If you go from an offset of 38 mm to 20 mms the wheel will be without spacers 18 mm closer to the car. Not good for neither handling or tyres getting close to the chassie...
Back to topic:
The right tire size would be 245/40 R18. I used to have that size wrapped on 8,5x18 ET15 rims without any problems, so to me it looks that the 8,5x18 ET38 + 20mm spacers + 245/40 R18 combo would work. I would recommend buying wheels with correct offsets though, because 20mm spacers sound quite much, especially for front axel.
^ Thats what i wanted to read. The wheels im looking at are 18x8.5 ET38 and im going to use 20mm spacers so essentially its ET18. thanks to all for the replies. Any more input?
