What resistor to use for led bulb reverse light
I was led to believe the led reverse lights I puchased from mike would only show an error message at startup and disappear. Turns out that is not the case and he will not refund me shipping costs which adds up to $10. The bulb itself $15. So I got screwed. Does anyone know what resistor I can use to cancel the error code.
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
http://forums.e60.net/index.php?s=&sho...st&p=670508
These are the ones I used for the license plates lights, 2 bucks!
I had it for 6 months now and it works great!
Originally Posted by aresh' post='843801' date='Apr 11 2009, 01:05 AM
Yea but which resistors will work?10ohm?
A 50 ohm 10W 5% Wirewound Resistor at each LED should trick the electronics that it has the same resistance as a conventional bulb.
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
