What are the biggest spacers i could put on???
My Ride: BMW E60
Hello!
I wanted to know what are biggest spacers i could put on: Wheels: Front and Rear: 8 x 18, ET 20
But i dont want to do anything else on the car.
Greets
Greets
My Ride: BMW E60
Originally Posted by NeRwEEzy' post='532553' date='Feb 17 2008, 10:59 PM
id say 5mm spacers.
Originally Posted by Mach_666' post='532608' date='Feb 18 2008, 01:44 PM
Are you sure?? I thought on 20 or 30 mm on each Wheel??!
My Ride: 04' 545i SMG , Oriental Blue, Congiac Leather Interior, Nav., Park Assist, Logic 7, Sports Pkg, Cross drilled slotted rotors, ceramic pads, SS Brake lines, free flow air filter and a supercharger (coming soon)etc.....all the good stuff
I am doing 12 or 15 in the in the rear
Depends on the tyre width you plan to use. It Is almost impossible for the rim to rub to the fender, or to the wheel wells.
Ie. an 8J rim with 10mm spacer fitted and with a 245 tyre mounted won't rub, whereas the same setup, but with a 255 tyre, may rub.
Assuming that you have the stock 245 tyres all around, you can go for up to 7 mm spacer - 8 mm max front and up to 15mm spacer - 16 mm max rear, leaving space for a 2-3mm gap.
Available space front stock with 8JX18ET20 and 245/40R18 tire: 10 mm
Available space rear stock with 8JX18ET20 and 245/40R18 tire: 18 mm.
My Ride: BMW E60
I have measured > 25 mm free space till the fender edge...
In the past summer i had 20 mm all around, but there was even more free space... soi thought on 30 mm??
i have 235 / 40 / 18
thx
Originally Posted by Mach_666' post='532706' date='Feb 18 2008, 07:19 PM
Hello Nick!
thx
thx
At front, the tire is rubbing to the inner plastic wheel well's center - right above the tyre, not to the fender's arch.
In the rear it will rub to the inner arch, between the upper and the rear end of the wheel arch.
You can only measure correctly with the springs fully pressed.
If you have 235/40 then you can add +4 mm to the spacers above.
Originally Posted by Mach_666' post='532715' date='Feb 18 2008, 07:51 PM
then the 20 mm all around were quite the limit??
thanks
thanks
Kbc
07-27-2015 05:51 PM
