Well this rim and tire pkg fix 530I
Hello everyone, I'm looking buy a set of OEM M5 Rims with Continental ContiSport Contact2 tire package.
Size: 19x8.5 front / 19x9.5 rear
Bolt Pattern: 5x120
Hub Bore: 72.56mm
Offset: 12mm front / 28mm rear
Tires: Continental ContiSport Contact 2: Front: 255/40/ZR19, Rear: 285/35/ZR19
well this fit on 04 530I, or I need to get a different offset and tire to fit on my car.
Thanks
Bolt Pattern: 5x120
Hub Bore: 72.56mm
Thanks
Originally Posted by Bteljuice' post='622047' date='Jul 12 2008, 09:11 AM
245/35/19 front and rear 275/30/19
or else you will get some rubbing. GL
On the front he absolutely needs to run 245/35-19. He can run 285/30-19 without rubbing on the rear. He is planning on using M166's with ET28mm M5 offset.
If he were to run M166's with ET17mm M6 offset, then he would have rubbing issues and would need to run 275/30-19.
My Ride: 08 Porsche 911 c2s, 01 BMW 740il, 05 BMW 525i, 06 Acura TSX navi
Originally Posted by Leo-2004-BMW' post='622341' date='Jul 12 2008, 10:14 PM
Thanks Bteljuice for the info.
RJH&CO - do you know any good sponsor or seller on the board that sell OEM M5 166 RIMS? thanks
and their retail is def. lower than my local dealer retail.
but if u found a set used, u will just need the tires changed to not rub.
GL. it's gonna looks sweet man.
Think going thru gary for 166's will be 1495 + shipping...as I've read on numerous posts...
pull the trigger.
what brand tire would u go with?
